I am using trying to develop a driver with 3.18 API. In the past (before cmake) it was possible to run the drivers as debug in visual studio, or via command line with -proj.
Now it doesnt seem to be possible anymore and I get issue regarding QMutex : Entry Point Not Found
Do I miss something? I tried with the default generated driver and I am getting the same issue.
Thanks.
Alex
Changes in API
- dgi
Re: Changes in API
you have two WinCC OA Versions installed right? Try to remove the old version from your Windows "PATH" variable, reboot, rebuild and retry.
BR,
Giri
BR,
Giri
