Install WinCCOA on Debian Linux
7 posts • Page 1 of 1
luis.bustamante
Post by luis.bustamante »
I have been trying to install WinCCOA on a virtual machine with Debian Linux 11 or Ubuntu 20, but I always get the same error with certain packages.
winccoa@debian-winccoa:~/Descargas/WinCC_OA_3.17_SIMATIC_Industrial_OS_2_P016$ sudo apt-get install ./*.deb
or
winccoa@debian-winccoa:~/Descargas/WinCC_OA_3.18_SIMATIC_Industrial_OS_2_P007$ sudo apt-get install -f ./WinCCOA-3.18.7-Base-debian.x86_64.deb
Los siguientes paquetes tienen dependencias incumplidas:
winccoa-3.18-base : Depende: libicu63 (>= 63.1-1~) pero no es instalable
Depende: libxcb-util0 (>= 0.3.8) pero no es instalable
E: No se pudieron corregir los problemas, usted ha retenido paquetes rotos.
Does anyone know if it is possible to install WinCCOA on a clean Debian based distribution installation ?
Or do que need to install some extra packages.
Luis Miguel BP.
Re: Install WinCCOA on Debian Linux
If you want to install WinCC OA please first have a look a the list of supported operating systems.
For WinCC OA 3.18 the following Linux distributions are supported:
Linux RedHat - Enterprise Linux 8 64bit (Build-Version: 8.4)
Oracle® Linux - Oracle® Linux 8.4 (Build-Version: 8.4)
SIMATIC Industrial OS - SIMATIC Industrial OS 2.2
Debian 10 - Debian 10 (Buster) Only supported within a Docker environment
luis.bustamante
Hello leoknipp.
Thank you very much for your response.
Finally I will use Oracle Linux.
By the way I consider Debian a very good choice in the Linux ecosystem.
Luis Miguel BP.
gschijndel
Post by gschijndel »
SIMATIC Industrial OS 2.x is based on Debian 10, so on that version the installation might be possible.
luis.bustamante
Hello gschijndel,
I installed WinCCOA 3.18 on Debian 10 + XFCE and it worked correctly, very light and very fast.
Thank you very much.
Luis Miguel BP.
Please take into account that Debian 10 is only supported in a Docker environment, see list of supported operating systems.
luis.bustamante
Hello leoknipp.
Yes I understand, it is for development and local testing purposes only, it is not for production.
Thank you very much for your clarifications.
Luis Miguel BP.
