Hello everyone
Our customer is using the httpServer-Manager.
Whenever Firefox is opened and the service is contacted for the first time, the following log message appears:
WCCOActrl (2), 2022.01.28 10:18:28.086, SYS, SEVERE, 141, Connection to client could not be encrypted:
WCCOActrl (2), 2022.01.28 10:18:28.088, SYS, SEVERE, 141, Connection to client could not be encrypted:
This message appears only for the first time when logging on until Firefox is closed and opened again.
Since there are 2 spaces between the words "client" and "could", I assume there is a missing name or IP address.
Has anyone ever experienced this issue and has an explanation and / or a solution?
€: it's CentOS 8 and WinCC OA 3.17 P012
Connection could not be encrypted
- kilianvp
Re: Connection could not be encrypted
Firefox first tries to use http and then switches to https. Firefox remembers this until you close the browser. You can ignore the message.
- weirdal
Ok, thank you for the quick answer, Kilian.
That explains the log messages and the pattern in which they occur.
The bookmark I am using is stored as "https://..." tho, I would expect Firefox to explicitly not use HTTP in this case.
Is there a setting in Firefox to force it to only use HTTPS? I could not find one.
- weirdal
I found out that Firefox actually has a HTTPS only mode, but it is available only from version 83.x while CentOS 8 comes with Firefox v78.3.0 by default.
I am assuming, but have not tested, that this might get rid of the mentioned log message.
