Can I import the externally developed dll file to WinCC OA?
8 posts • Page 1 of 1
BongBongV
Post by BongBongV »
I'm going to make the developed program in dll format and import it inside WinCCOA, is it possible?
After making that program into a dll,
[ui]
CtrlDLL = "Test"
I wonder if I can use it in this format.
Unexpected state, The Ctrl Extension D:\GIT_PROJECT\SCRIPT\NEW_PLATFORM\NEW_PLATFORM\bin\CreateDLL.dll is not compatible with the current library version 318000 of WinCC OA.
It might be from version <= 3.6, or a needed external library could not be loaded. (See also previous error message)
How can I get you to refer to an external library?
If externally developed dll can be used, is there a license condition required to use it?
Re: Can I import the externally developed dll file to WinCC OA?
You have to create a Ctrl Extension if you want use your functions inside a CTRL Script. You have to use the offical WinCC OA C++ API. Or you write a foreign function interface (FFI) for CONTROL and load a DLL.
BongBongV
Post by BongBongV »
Thank you for your answer.
How can I make FFI(foreign function interface) between WinCC OA's CTRL and C++?
Do you have an example?
gschijndel
Post by gschijndel »
An example can be found on github. It is called CtrlFFI. But perhaps there is a fork, which is a better starting point.
BongBongV
Post by BongBongV »
Thank you, Have a good day.
It's my fork. I'll update it to cmake soon.
gschijndel
It would be nice if ETM includes this in the product or at least have it compiled available.
Yes
