Hello!
How to use the CONTROL script to find out when the project was launched (for example, the Event Manager)?
Best regards, Ilya
How to find out when the project was launched
- kilianvp
Re: How to find out when the project was launched
well if you run a CONTROL script without "-n" option the event manager is already running.
- i.mak
I need to know not what the event manager is running, but the exact time when it started working.
What for do you need the information when the project was launched?
Do you need the information inside of the WinCC OA project?
- i.mak
Yes, I need this information inside of the WinCC OA project.Do you need the information inside of the WinCC OA project?
What is done with that information?
- i.mak
Does the solution depend on the answers to these questions?What for do you need the information when the project was launched?
I can write to an internal data point at startup and then read from it when needed. But I thought there was a CONTROL function for that.
Thanks anyway.
Best regards, Ilya
Maybe there is a better solution for the requirement which should be solved.
Can you please give us the information what the information is needed for.
- i.mak
I need this information to display. In the same way as the start time of the managers is displayed in the WinCC OA console.
You can read the information from the process monitor.
For details please have a look at the documentation:
https://www.winccoa.com/documentation/W ... el-06.html
Another possibility is to read the information from the _Connections datapoint and its elements. At the element the information is saved when the connection was established between the Event Manager and other managers.
