Delete some configs of dpe by the script
7 posts • Page 1 of 1
Nikolay
Post by Nikolay »
Hi to all!
At some point of developing our project, we set a lot of unnecessary datapoint functions and alert handling, but now we decided that it is no use for us and wish for cleaning para from unnecessary configs. But we have a lot of dpe-s and tags with it, so we are looking to a more quicker way to delete it by script, but still to no avail. Maybe someone has a solution? Thanks
Re: Delete some configs of dpe by the script
If a config shall be deleted you can simply do a dpSet() for the _type attribute with the CTRL constant DPCONFIG_NONE.
It is better to use a dpSetWait() in combination with getLastError() to check if an error occured.
Nikolay
Post by Nikolay »
Wow, thanks a lot, will do!
Nikolay
Post by Nikolay »
Well, that didn’t work out as we expected. After we make dpSet with DPCONFIG_NONE, we looked in the PARA - and there was none dp_fct, but when we reopened script with dpNames by _dp_fct..fct - list of signals still contained deleted dp_fct.
Request of dp_fct: dpNames(tag+”:_dp_fct.._fct”);
or
dpNames(tag+”:_dp_fct.._type”);
Deleting: dpSet(tag +”:_dp_fct.._type”, DPCONFIG_NONE);
Whats the Value of _dp_fct.._type if do a dpGet? DPCONFIG_NONE?
As written in my previous answer it is better to use dpSetWait() and getLastError() to get the information if the dpGet() worked.
Also please check the PVSS_II.log file to see if a log message was written.
If you want to delete specific configs you should probably check if the config is existing before trying to delete it, e.g. by using a dpQuery() with a WHERE clause.
gschijndel
Post by gschijndel »
Nikolay wrote: ↑ Mon Dec 13, 2021 1:22 pmwhen we reopened script with dpNames by _dp_fct..fct - list of signals still contained deleted dp_fct.
dpNames cannot be used to check if a config exists. For configs it will simply list all possible attributes of that config regardless if a dpe with specified or not.
