Hello everyone,
I need help about redundancy feature again. I have a control manager with runnning a script. Also I have 2 server for redundancy. I want to resetting this control manager when master (running server-preferred server) change.
How can I do? Can you help me?
Thank you!
Resetting Control Manager(Script)
- kilianvp
Re: Resetting Control Manager(Script)
You can use sysConnect() and use the "redu" event. If redu change the callback will called
- emreamirim
Thank you kilianvp, I used this function and have seen results but it helps only understanding changing of servers. After this point I want to stop a manager/script.kilianvp wrote: ↑ Wed Nov 17, 2021 10:59 pm You can use sysConnect() and use the "redu" event. If redu change the callback will called
Found on help as "stopManager()" but I can not run it.
- kilianvp
if you call exit() inside the manager it will stop. But don't forget to set the startmodus to manual.
- gschijndel
Why do you need to restart a control manager after a redundancy switch over?
- denisisakovic
I think you don't need to worry about that, when the server activity switches between ACTIVE and PASSIVE servers, the event manager ignores activities (dpset and so on) from the script that is running on the new PASSIVE server.
If the start mode is "manual" the manager will not restart automatically.
As written in the previous post a message to modify a datapoint/alert instance will be discrarded by the passive Event Manager.
An exception are all DP elements which are defined using the fwdDp/fwdDpType entries.
- emreamirim
Thank you very much for all replies, I will try all.
Thank you again everyone.
Because I have a control manager (written by another programmer) that need to restart for work correctly. I can not change anything inside of script.gschijndel wrote: ↑ Fri Nov 19, 2021 10:05 am Why do you need to restart a control manager after a redundancy switch over?
