Just got a new laptop and I would not want to change Excel to 32-bit.
Is there any workaround or MaPara available for 64-bit?
64-bit Excel add-in MaPara
Re: 64-bit Excel add-in MaPara
The MaPara Excel Add-In and also the Excel Report are only available for 32bit Excel.
- funkey
You can save your Import-Excel-File as a tap separated file. Then change it from ANSI to UTF8 code if you have Umlauts in text.
After that you can use a batch file to direct start WCCOAASCII app for importing.
Here is my batch file, you may have to adapt it:
Hope this helps.
rem %1 ist der Pfad zur ASCII-Import-Liste
rem %2 ist der DPT; z.B. Antriebe oder Analogwerte
C:\Siemens\Automation\WinCC_OA\3.17\bin\WCCOAASCII -in %1 -PowerConfig -filterDpType %2 -user root: -config C:\pvss\WinCC_Project\config\config -log +stderr 1>Import_Error.txt 2>&1
