InfluxDB problem
Victor.Ermakov
InfluxDB problem
Post by Victor.Ermakov »
Hi.
I have a problem with the InfluxDB manager.
Restarting WCCOAnextgenarch and the entire project did not fix this issue.
I'm using WinCC OA v3.17 P14.
Error log below:
WCCOAnextgenarch(118), 2021.11.10 09:24:07.314, IMPL, WARNING,    69, Database error, Some alerts are within read-only shards. Taking single-insert code path (will be slower) (from _NGA_B_CENTRAL_DB)
WCCOAnextgenarch(118), 2021.11.10 09:24:07.531, IMPL, SEVERE,     69, Database error, partial write: points beyond retention policy dropped=2 (from _NGA_B_CENTRAL_DB)
WCCOAnextgenarch(118), 2021.11.10 09:24:18.682, IMPL, WARNING,    69, Database error, Some alerts are within read-only shards. Taking single-insert code path (will be slower) (from _NGA_B_CENTRAL_DB)
WCCOAnextgenarch(118), 2021.11.10 09:24:19.818, IMPL, SEVERE,     69, Database error, partial write: points beyond retention policy dropped=2 (from _NGA_B_CENTRAL_DB)
WCCOAnextgenarch(118), 2021.11.10 09:24:29.930, IMPL, WARNING,    69, Database error, Some alerts are within read-only shards. Taking single-insert code path (will be slower) (from _NGA_B_CENTRAL_DB)
WCCOAnextgenarch(118), 2021.11.10 09:24:31.221, IMPL, SEVERE,     69, Database error, partial write: points beyond retention policy dropped=2 (from _NGA_B_CENTRAL_DB)
WCCOAnextgenarch(118), 2021.11.10 09:24:39.280, IMPL, WARNING,    69, Database error, Some alerts are within read-only shards. Taking single-insert code path (will be slower) (from _NGA_B_CENTRAL_DB)
WCCOAnextgenarch(118), 2021.11.10 09:24:40.742, IMPL, SEVERE,     69, Database error, partial write: points beyond retention policy dropped=2 (from _NGA_B_CENTRAL_DB)
WCCOAnextgenarch(118), 2021.11.10 09:24:50.756, IMPL, WARNING,    69, Database error, Some alerts are within read-only shards. Taking single-insert code path (will be slower) (from _NGA_B_CENTRAL_DB)
WCCOAnextgenarch(118), 2021.11.10 09:24:52.293, IMPL, SEVERE,     69, Database error, partial write: points beyond retention policy dropped=2 (from _NGA_B_CENTRAL_DB)
WCCOAnextgenarch(118), 2021.11.10 09:25:01.379, IMPL, WARNING,    69, Database error, Some alerts are within read-only shards. Taking single-insert code path (will be slower) (from _NGA_B_CENTRAL_DB)
WCCOAnextgenarch(118), 2021.11.10 09:25:03.128, IMPL, SEVERE,     69, Database error, partial write: points beyond retention policy dropped=2 (from _NGA_B_CENTRAL_DB)
WCCOAnextgenarch(118), 2021.11.10 09:25:11.486, IMPL, WARNING,    69, Database error, Some alerts are within read-only shards. Taking single-insert code path (will be slower) (from _NGA_B_CENTRAL_DB)
WCCOAnextgenarch(118), 2021.11.10 09:25:13.121, IMPL, SEVERE,     69, Database error, partial write: points beyond retention policy dropped=2 (from _NGA_B_CENTRAL_DB)
WCCOAnextgenarch(118), 2021.11.10 09:25:21.882, IMPL, WARNING,    69, Database error, Some alerts are within read-only shards. Taking single-insert code path (will be slower) (from _NGA_B_CENTRAL_DB)
WCCOAnextgenarch(118), 2021.11.10 09:25:23.062, IMPL, SEVERE,     69, Database error, partial write: points beyond retention policy dropped=2 (from _NGA_B_CENTRAL_DB)
WCCOAnextgenarch(118), 2021.11.10 09:25:31.755, IMPL, WARNING,    69, Database error, Some alerts are within read-only shards. Taking single-insert code path (will be slower) (from _NGA_B_CENTRAL_DB)
WCCOAnextgenarch(118), 2021.11.10 09:25:32.606, IMPL, SEVERE,     69, Database error, partial write: points beyond retention policy dropped=2 (from _NGA_B_CENTRAL_DB)
WCCOAnextgenarch(118), 2021.11.10 09:25:42.420, IMPL, WARNING,    69, Database error, Some alerts are within read-only shards. Taking single-insert code path (will be slower) (from _NGA_B_CENTRAL_DB)
WCCOAnextgenarch(118), 2021.11.10 09:25:44.487, IMPL, SEVERE,     69, Database error, partial write: points beyond retention policy dropped=2 (from _NGA_B_CENTRAL_DB)
WCCOAnextgenarch(118), 2021.11.10 09:25:53.366, IMPL, WARNING,    69, Database error, Some alerts are within read-only shards. Taking single-insert code path (will be slower) (from _NGA_B_CENTRAL_DB)
WCCOAnextgenarch(118), 2021.11.10 09:25:54.462, IMPL, SEVERE,     69, Database error, partial write: points beyond retention policy dropped=2 (from _NGA_B_CENTRAL_DB)
Re: InfluxDB problem
For the analysis we would need the complete log files and more detailed information.
If you want to get assistance please get in contact with your common WinCC OA support.
