Message conversion Counter pulses
JukkaP
Post by JukkaP »
I would like to calculate rising edges of a trigger bit.
In Para, I made a config "Message conversion" for the trigger bit DPE (type bool) and selected Counter pulses with property "Change 0-> 1".
My question is, how can I read the counter value (result) into another DPE (type int).
Re: Message conversion Counter pulses
The message conversion _msg_conv can only be used for a DP element which receives values from a peripheral device as the driver is using this config.
If a value is received from the device the driver does the calculation defined in the config and writes the result to the original value.
