Variable not defined in cnsTree_viewPermissionInitThread
Stijns
Post by Stijns »
See the following log:
WCCOAui      (7), 2021.10.21 15:26:12.073, CTRL, SEVERE,    176, Uncaught exception in thread started at cnsTree_viewPermissionInitThread:
WCCOAui      (7), 2021.10.21 15:26:12.073, CTRL, SEVERE,     73, Variable not defined,
    Module: CNS_MODULE_EDITOR_VIEW
    Panel: C:\Siemens\Automation\WinCC_OA\3.18\panels\vision\cns\cnsMain.pnl [editor]
    In reference: vision/cns/objects/cnsTreeObject.pnl Group: 0 named: "treeFilterRef"
      used in:    vision/cns/objects_parts/ref_cnsTreeFilter.pnl Group: 0 named: "treeFilterRef"
    Script: Initialize
    Library: C:\Siemens\Automation\WinCC_OA\3.18\scripts\libs\cnsTree.ctl
    Line: 1575, sDp
	Stacktrace:
	     1: void cnsTree_viewPermissionInitThread(anytype aTree, dyn_dyn_anytype dda) at cnsTree.ctl:1575
Bug found in WinCC OA 3.18P004
Re: Variable not defined in cnsTree_viewPermissionInitThread
This problem is already known and our developers will work on it.
When it will be fixed with a patch is not defined right now.
