How to use a different template according to a user ?
Nicolas
Post by Nicolas »
In my application, I have 3 users on 5 remote UIs. On each remote UI, each user can connect itself but for each user, a different template shall be used. For example:
- for the user1, the template has a top menu (naviPanel), a bottom menu (infoPanel) and the basePanel
- for the user2, the template has only another bottom menu (infoPanel) and the basePanel
Is it possible to load a different template according to the user connected ?
Re: How to use a different template according to a user ?
When using the login panel you have the possibility to change the user specific monitor configuration.
Please check if this option can be used to fulfill your requirements.
