Recently i had to use a remote UI client for my winccOA project and i have managed that succesfully. I am using SIMATIC ITC1900 V3 for my remote UI. Is it possible to retrieve log file from that UI?
Remote UI client log file
Re: Remote UI client log file
Currently there is no easy possibility to get the log files saved on an ITC client.
Why do you want to "download" the log files?
- denisisakovic
I have tried to use function "setScaleStyle(SCALE_FIT_TO_MODULE, moduleName)" in my embedded module to fit panels with bigger size than the display size of that ITC client (which is 1366 x 768 pixels). It works fine when testing locally on my laptop, but it won't work on the HMI.
So maybe by looking into the log file I could get more information regarding that problem.
Edit:
Regarding the log file, I am only interested for the UI log file which is generated by the peroject itself, not the other logs (those which the ITC client generates, if there are any)
Edit:
As written in my previous post accessing the WinCC OA log files is not possible in an easy way. As far as I know you would need direct access to the file system which requires special permissions.
I am pretty sure that setScaleStyle() will not return an error or a log entry if it does not work. Possibly only a log message will be written if the passed parameters are wrong.
If you need further assistance you can possibly get in contact with your common WinCC OA support.
