Dashboard (WSS Server)
juma4
Post by juma4 »
Good day
We are trying to reach the new dashboard function via https. When you log in, the message "Check the WSS server" always appears.
If the dashboards are accessed via http "only using Edge", it works.
Unfortunately, I am stuck and would be happy to receive help with the problem.
Thank you very much
Markus
Re: Dashboard (WSS Server)
I have tested it and I got the same error.
This issue will be discussed with our developers. When an answer is available this thread will be updated.
In the Chrome browser it worked from the beginning.
When using Firefox I had to do a little trick. After calling once https://<hostname>:8449 (8449 is the standard port for the Dashboard server) the Dashboard worked also in Firefox.
