I'm trying to create an S7+ connection against a S7 1500 PLC redundant system online but, whenever I push "Create" button, inside the s7plus.pnl, I get this message:
WCCOAui (1), 2021.08.11 11:47:23.435, CTRL, WARNING, 71, DP does not exist,
Module: WinCC_OA(1)
Panel: C:\Siemens\Automation\WinCC_OA\3.18\panels\para\s7plus.pnl [S7+ configuration]
Object: 27 named: "cmdNewDp" of type: PUSH_BUTTON
Script: Clicked
In panel scope library: C:\Siemens\Automation\WinCC_OA\3.18\panels\para\s7plus.pnl
Line: 123, dpSet, _CSD.Config.Tspp.Mode
I started having this issue when migrating my project from 3.17 to 3.18 WinCCOA version.
Is it a 3.18 bug or is there anything I'm missing during connection creation?
S7+ Connection creation
Re: S7+ Connection creation
I checked the structure of the _S7PlusConnection DP type and it should have an element called Config.Tspp.Mode in 3.18.
How did you do the migration from 3.17 to 3.18?
