A surprise after 18 years of WinCC OA
An off-topic general discussion forum to chat about ANYTHING!
fmulder
Post by fmulder »
One of the nice things of OA is the possibility to play with data types. Assign an int to a string, an int to string etc.. It is often quite usefull that you do not really think about data types and just assign them as you wish.
I'm sure (or at least I hope so ) that you all, at some time, have assigned a string to a boolean. Example:
* You read a value 'false' from a file or database
* and then just assign it to a boolean
string conditionFromFile = FileRead( ... )
bool bCondition = conditionFromFile ;
Todat, one of my colleagues types the magic word 'False' in a database with an effect that suprised me. I then wrote the following small script to demonstrate.
main()
  DebugN( "False -> " + (bool)"False" );
  DebugN( "false -> " + (bool)"false" );
  DebugN( "True -> " + (bool)"True" );
  DebugN( "true -> " + (bool)"true" );
The result in the LogViewer ?
WCCOAui1:["False -> TRUE"]     <== !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
WCCOAui1:["false -> FALSE"]
WCCOAui1:["True -> TRUE"]
WCCOAui1:["true -> TRUE"]
I can't this a bug because we all know that I should have checked the string. Still, I've assigned string to integers, floats and booleans for years and never realised this behavior
Hope it helps someone
share the fun
Frenk Mulder
Re: A surprise after 18 years of WinCC OA
Casting "FALSE" or "false" work as expected. Everything else has always been true. Just do strtolower or strtoupper. It's similar in other languages! I did my Tests in 3.12 and 3.18
main()
  // works as intended
  DebugN( "0 -> " + (bool)"0" );
  DebugN( "1 -> " + (bool)"1" );
  DebugN( "FALSE -> " + (bool)"FALSE" );
  // always true
  DebugN( "3 -> " + (bool)"3" );
  DebugN( "winccoa -> " + (bool)"winccoa" );
WCCOAui0:["0 -> FALSE"]
WCCOAui0:["1 -> TRUE"]
WCCOAui0:["false -> FALSE"]
WCCOAui0:["FALSE -> FALSE"]
WCCOAui0:["true -> TRUE"]
WCCOAui0:["3 -> TRUE"]
WCCOAui0:["False -> TRUE"]
WCCOAui0:["True -> TRUE"]
WCCOAui0:["winccoa -> TRUE"]
