Error while reading the alarm class value from DIST system
paramesh1985
Post by paramesh1985 »
I am getting the below error while using the dpGet for remote system.
WCCOAui (7), 2021.07.22 11:45:35.716, IMPL, WARNING, 54, Unexpected state, DpIdentifier, formatValue, could not convert DpIdentifier to string: (Type: 0 Sys: 10 Dp: 100082634 El: 0 : ..)
WCCOAui (7), 2021.07.22 11:45:35.719, IMPL, WARNING, 54, Unexpected state, DpIdentifier, formatValue, could not convert DpIdentifier to string: (Type: 0 Sys: 10 Dp: 100082634 El: 0 : ..)
WCCOAui (7), 2021.07.22 11:45:35.721, IMPL, WARNING, 54, Unexpected state, DpIdentifier, formatValue, could not convert DpIdentifier to string: (Type: 0 Sys: 10 Dp: 100082636 El: 0 : ..)
WCCOAui (7), 2021.07.22 11:45:35.724, IMPL, WARNING, 54, Unexpected state, DpIdentifier, formatValue, could not convert DpIdentifier to string: (Type: 0 Sys: 10 Dp: 100082636 El: 0 : ..)
Any idea on this.
Re: Error while reading the alarm class value from DIST system
The DP ID information does not contain the type information and therefore resolving the DP ID possibly fails.
The DP ID is very high (100.082.636). Do you know which such a high ID is used?
Possibly you can check in System 10 if the DP ID 100082636 can be resolved to a valid DP name.
