Ok to use _ArchivDisk_2 in my project?
Smiffy
Post by Smiffy »
I am wanting to perform an action (remove archive backup files) when disk space gets below a certain limit.
I have discovered a DiskSpaceCheck datatype in the dp.
I have looked into this and fond that if I populate the .Device entry, the system will update entries regarding disk parameters (free space / used space etc.).
This is just what I am after.
I also noticed that there were 2 data points for archiving _ArchivDisk and_ArchivDisk_2.
The former was being used for the project db directory.
The latter seemed to be unused as the .Device entry was blank.
Is it OK to use the _ArchivDisk_2 entryfor my own use? Does the system use it at all? If it is not permissible to use _ArchivDisk_2, can I just define another DiskSpaceCheck data point type and it will be populated also?
Re: Ok to use _ArchivDisk_2 in my project?
The "_2" datapoints are preserved for redundant projects.
Normally you should have a _BackupMedium datapoint which can be used to check the disk space for the backup device.
The configuration of new "Disk space check" datapoints is possible using the System Management.
