ascii error in dpl file
paramesh1985
Post by paramesh1985 »
Any one have idea i am getting ascii error -50 while importing the dpl file.
Any solution to fix the problem.
regards,
r.parameshwaran
Re: ascii error in dpl file
When doing an ASCII import using the WinCC OA panel two "ascii" log files are written.
If you look at these files you should find the cause for the return value "-50".
paramesh1985
In the ascii log file i got only the below information there is no detailed info;
WCCOAascii (0), 2021.07.07 17:00:36.562, SYS, INFO, 1, Manager Start, PROJ, LFF_MAIN, V 3.12 - 3.12 platform Windows AMD64 linked at Mar 2 2017 22:07:26
WCCOAascii (0), 2021.07.07 17:00:36.562, SYS, INFO, 3, Trying to connect to, (SYS: 0 Data -num 0 CONN: 1) @ X862KS0501:20897
WCCOAascii (0), 2021.07.07 17:00:36.564, SYS, INFO, 4, Connected to, (SYS: 0 Data -num 0 CONN: 1) @ hostname (::1)
WCCOAascii (1), 2021.07.07 17:00:42.146, SYS, INFO, 6, Initialization by Data Manager finished
WCCOAascii (1), 2021.07.07 17:00:42.146, SYS, INFO, 3, Trying to connect to, (SYS: 20 Event -num 0 CONN: 1) @ hostname:20998
WCCOAascii (1), 2021.07.07 17:00:42.147, SYS, INFO, 4, Connected to, (SYS: 20 Event -num 0 CONN: 1) @ hostname (::1)
WCCOAascii (1), 2021.07.07 17:00:42.174, SYS, INFO, 102, Waiting for user names/passwords
WCCOAascii (1), 2021.07.07 17:00:42.249, SYS, INFO, 103, User names/passwords initialized
WCCOAascii (1), 2021.07.07 17:04:38.743, SYS, INFO, 2, Manager Stop
doAsciiIn returned error code: -50
As written in my previous post you will have 2 "ascii" log files when using the WinCC OA panel for the import.
Please check both files to get all the information.
