Tell me please, how can I backup a WinCC OA project without database data?
The WinCC OA project is about 4Tb size with database data.
BackUp WinCC OA project without database data
- MassEffect
Re: BackUp WinCC OA project without database data
In the panel for the Online Backup you can do a backup of the database or the configuration (tab "Parameterization").
When you do the backup for the configuration an ASCII export is made and the other project data (except the db directory) is copied to the backup directory.
In the configuration for the database backup you can define for which time range data shall be copied to the backup device.
If you select a short time range you will not have so much data.
