Our project faced a weird problem. This project has run for 5 years.
WinCC OA v3.14 P014 under Windows server 2012 R2 Standard.
The peripheral address config disappeared after the server restart.
There are errors in logviewer.
69, Database error, StVariableUtils, LoadVariable
54, Unexpected state, ManagerInitialiser, refillConfigInitList, DpConfig nicht ladar:
SSH0000202.PT22.setPointW:_address (Type:0 Sys:0 Dp:12373 EL:194 : _address..0)
69, Database error, DataManTask, dbError, RAIMA Database Error *** Code:-6 (PROGRAMMER/USER error:-6)
How can I do to fix this problem?
Peripheral Address config disappear after the server restart
- BenjaminSeeker
Re: Peripheral Address config disappear after the server restart
Possibly the database part where the configs are saved is damaged.
You can try to solve the problem with the following procedure:
https://www.winccoa.com/knowledge-base/ ... e7bf783734
If now already configs are lost you have to check after the initialization of the database if still errors occur and if configs are lost.
The missing ones you have to create again.
- BenjaminSeeker
Thanks. I will check and try to repair it. I will let you know if any progress.
- BenjaminSeeker
The connection is invalid, I can not visti. could u generate a new one. thanks.leoknipp wrote: ↑ Fri Jun 25, 2021 5:30 pm Possibly the database part where the configs are saved is damaged.
If the link does not work you can search for "How to initialize the configuration history?" in the Knowledge Base.
https://www.winccoa.com/knowledge-base/ ... 48d5e60d4f
