Clearing a text field which has a float format?
- tpjctrl
Anyone has any ideas on how to clear (ie. remove all shown text) a text field which is set to a float format? The usual textfield.text = ""; simply sticks a "0" in the textfield rather than wiping the contents. Format swap from float to string, then clear, then swap back to float also doesn't work as the textfield shows a "0" as soon as format goes back to float.
- kilianvp
Re: Clearing a text field which has a float format?
what should be in the text field? Completely empty?
- tpjctrl
Yes that was the plan, the idea is to clear it completely (ie. remove any numbers from it) after the user enters a number and clicks a button to process an action. Not even sure if this is possible with float format text fields tbh.
- kilianvp
This is not possible. The default value is always taken. For string the default value "" and for float 0.0 -> 0tpjctrl wrote: ↑ Tue Jun 22, 2021 1:43 pm Yes that was the plan, the idea is to clear it completely (ie. remove any numbers from it) after the user enters a number and clicks a button to process an action. Not even sure if this is possible with float format text fields tbh.
- ozangor
Hi there,
I think updating the format in KeyboardFocusIn/Out events might be helpful for you.
Keep your textbox format as string, update the format back to float when KeyboardFocusIn is triggered (when typing cursor appears).
When your action button is clicked, you can set the format back to string and value to empty string.
- tpjctrl
Thanks ozangor!
