AEScreen and AESrow to display miliseconds
AMRPatricio
Post by AMRPatricio »
Hi All,
How can configure the time stamp of AEScreen and AESrow to display miliseconds?
Thank you.
Antonio
Re: AEScreen and AESrow to display miliseconds
I checked the code and it looks like there is no possibility in the standard AEScreen to show the time stamps with milliseconds.
ro.w
Post by ro.w »
Hi Antonio,
just go to System Managment/Settings/A&E - Row/Screen. The AES Table configuration opens now. Go to the Tab "Alerts" (or AlertRow for AES row) and then double click the relevant line (for example timeStr) where you want to show the time. In the configuration window that opens now, just delete the string %c in the text field "Format" (for all languages). Apply and restart UI. This "clean" format contains the miliseconds. Maybe there are other format strings that works here, too...
Rob
Indrani125
Post by Indrani125 »
can you explain with snap or give your code?Is it possible in available alarm screen?
You do not have to write code to display the milli seconds in the AEScreen.
If you remove a format setting in the settings for the AEScreen tables (System Management --> Settings --> A&E - Row/Screen) the AEScreen will display the time in a standard format YYYY.MM.DD hh:mm:ss ms
