Hello guys!
Unfortunately we can not export or import any ascii files.. the log says following:
WCCOAascii (0), 2021.06.17 11:29:29.480, SYS, SEVERE, 69, Database error, TypeAndIdDb, open
doAsciiOut returned error code: -2
Has anyone had the same problem with ascii manager or has some hints to solve this problem?
Thank you very much in advance!
ascii manager - export / import not possible
- paramesh1985
Re: ascii manager - export / import not possible
I think dataBG manager is not running .
please check in the task manager whether databg manager is running or not.
If not please restart the project then try whether its working or not.
regards,
r.parameshwaran
regards,
r.parameshwaran
- mathmm
thank you, but restart did not fix the problem.
Are you possibly trying to make an ASCII export on a client machine?
An ASCII export you always have to make directly at the server.
