I have a panel which holds a panel ref which has a read only textEdit widget inside. In the CSS the following is specified for textEdit widgets:
QTextEdit[type="material"][readOnly="true"]
color: rgb(174,178,182);
background-color: rgb(36,38,45);
If I run the panel in full screen mode, the CSS is applied correctly, but if I resize it to "window" mode and reload the panel, the CSS stops applying and instead the original colours from the textEdit properties are used instead. Any ideas why?
Using WinCC OA 3.17 P011.
.css stylesheet not applied in "window" mode?
- tpjctrl
Re: .css stylesheet not applied in "window" mode?
I have tested it with 3.17 P012 and I cannot see a difference if the module is in full screen mode or not.
Do you have a simple example where we can see the problem?
- tpjctrl
It seems that the stylesheet issue only happens if the textEdit has the fore / back colours set to something else than _Window / _WindowText, if you leave them at the default _Window / _WindowText the stylesheet rules get applied regardless of whether the module is in full screen or not.
