OriginTime of QueryConnect hotlink not set
dgi
Post by dgi »
I just observed with WinCCOA 3.16 on linux, that the OriginTime (DpHLGroup::getOriginTime(), C++ API, described as time when value change occured) of DpQueryConnect hotlinks is not set. Is this intended behaviour? In alertConnect and dpConnect hotlinks this value holds the time of the value change.
BR,
Giri
Re: OriginTime of QueryConnect hotlink not set
Where in the API did you find this information?
In a query result (in CTRL) you do not get the information for the _stime if the item is not added to the list of queried attributes.
Possibly it is the same in API.
In case of a connect to _alert_hdl attributes you have to be aware that the time information is the time when the alert was changed and this must not be the time when the values was set in some cases.
dgi
Post by dgi »
leoknipp wrote: ↑ Mon May 17, 2021 9:57 am Where in the API did you find this information?
Within the C++ API documentation (see attached screenshot).
leoknipp wrote: ↑ Mon May 17, 2021 9:57 am In a query result (in CTRL) you do not get the information for the _stime if the item is not added to the list of queried attributes.
Yes I know, but I am talking about HotLinkCallbacks, these are the messages which are received when DpConnect/QueryConnect(Single/All) callbacks are triggered and encapsulated by objects of the type DpHLGroup. This type features the getOriginTime() function (inherited by DpVCGroup), which is described to return the TimeVar of the value change. For DpConnect this is true, but for DpQueryConnect(Single/All) this time is not set, which does not make sense to me.
BR,
Giri
dgi
Post by dgi »
I am not able to attach screenshots... ("Sorry, the board attachment quota has been reached.")
Opening this uri with any webbrowser on a Windows System with WinCCOA installed should open up the documentation I am refering to:
file:///C:/Siemens/Automation/WinCC_OA/3.16/api/docu/class_dp_v_c_group.html
