I am trying to setup the NGA using the postgreSQL backend as described in the help.
At some step a folder structure needs to be made but it seems like an image is missing from the online help at this section.
I have tried setting up the db,alarms,events,backups folder in the db/NGA/postgreSQLBackend folder. This was my best guess where they should go.
Then i ran the batch file to create a DB (after changing the config). The nga manager returns the error that no active database could be found constantly. I have setup the correct 'localhost', port, username, and password in OA and PGAdmin.
Could a wrong installation (folder) of postgreSQL be the problem?
A faulty config somewhere?
Erik
PostgreSQL connection not working
- erik.schwing
Re: PostgreSQL connection not working
I Managed to get it working after a number of reinstallations of PostgreSQL database.
By default the installer will choose [Default locale] when creating the database, which for me was dutch_netherlands.12521.
With this locale the database connection does not work!
During the last reinstall i set the locale the english_Unitedstates and did the exact same steps to create the DB and it works.
