dpConnect callback in derived classes
1 post • Page 1 of 1
moto3101
Post by moto3101 »
Hello together,
please consider the following example:
class BaseClass
  public BaseClass()
    //default constructor
  public void init()
    setupConnect();
  protected void setupConnect()
    dpConnect(this, cbTestMethod, true, "Pump1.State"); //works
    dpConnect(this, "cbTestMethod", true, "Pump1.State"); //does not work
class ExtendedClass : BaseClass
  public ExtendedClass()
    //Default constructor
  public void cbTestMethod(string s, anytype a)
    DebugTN("callback triggered");
public void main()
  ExtendedClass logic;
  logic.init();
  dpConnect("cbTest", false, "Pump1.State"); //just to prevent the ctrl manager from exiting
public void cbTest(string dp, string state)
The first dpConnect works as expected, the second doesnt. Is there a reason why? Is there a way to still use the second dpConnect approach with the function name provided as string?
Background info:
The connect(s) are intended to be setup in the base class from a string configuration with callback function names (all callback functions follow the same name pattern).
Thanks in advance for your help!
