"PT_FavMgm.pnl" button-function doesn't work when placed on my project's template, but, if I load one of the default templates offered by Wincc OA, it perfectly works.
On my template, the "Favourite Management" window opens, but when trying to add a favourite user view, it always takes "StartPanel" and saves it, no matter what panel is actually being seen at the moment.
When trying to create a favourite view, logviewer shows this message:
WCCOAui (2), 2021.03.18 13:32:52.213, CTRL, SEVERE, 176, Uncaught exception in thread started at main:
WCCOAui (2), 2021.03.18 13:32:52.213, CTRL, SEVERE, 79, Index out of range,
Module: Vision_8
Panel: C:\Siemens\Automation\WinCC_OA\3.17\panels\para\msc\msc_FavMgm.pnl [Favourite management]
Object: 1 named: "tblFavourites" of type: TABLE
Script: SelectionChanged
In panel scope library: para\msc\msc_FavMgm.pnl []
Line: 51, dsUsed, 2
Stacktrace:
1: displayFavData() at [Module: Vision_8 Panel: para\msc\msc_FavMgm.pnl ScopeLib: msc_FavMgm.pnl]:51
2: main() at [Module: Vision_8 Panel: para\msc\msc_FavMgm.pnl Object: tblFavourites Script: SelectionChanged]:3
And, when trying to open the favourite view previously saved, logviewer shows this message:
WCCOAui (2), 2021.03.18 14:07:35.241, CTRL, SEVERE, 176, Uncaught exception in thread started at main:
WCCOAui (2), 2021.03.18 14:07:35.241, CTRL, SEVERE, 79, Index out of range,
Module: WinCC_OA_1
Panel: C:\WinCC_OA_Proj\MCC\panels\para\PanelTopology\templates\GTDL\basePanel_1920_1080_GTDL.xml [basepanel]
Object: 0 named: "casFavMgm" of type: CASCADE_BUTTON
Module: WinCC_OA_1
In reference: objects/STD_PANELS/PT_FavMgm.pnl Group: 0 named: "PANEL_REF1"
used in: objects/GTD_Footer/FooterLeft.xml Group: 13 named: "PANEL_REF79"
Script: Initialize
Script: Clicked
Library: C:\Siemens\Automation\WinCC_OA\3.17\scripts\libs\msc_multiScreening.ctl
Line: 491, dsUsed, 2
Stacktrace:
1: msc_useMenuId(string sUser = "root", int iMenuId = 3, string sMainModuleName = "mainModule_") at msc_multiScreening.ctl:491
2: main(string id = "2") at [Module: WinCC_OA_1 Panel: para\PanelTopology\templates\GTDL\basePanel_1920_1080_GTDL.xml Object: casFavMgm Script: Clicked]:3
Could you please give me any clue/advise about where should I take a look at in my template's project to solve this?
Favourite button issue
Re: Favourite button issue
The settings for the favourites are saved in a datapoint called _<User ID>_UiConfiguration at the type _Ui_Config. The datapoint has a lot of string arrays to save data.
Possibly the settings in the element of this datapoint are not correct and therefore you get the "index out of range" error.
