Having a boolean datapoint element, I want the AES/Events list to display only the 'TRUE' state of it.
Is there any well-known mechanism to achieve this?
Thank you,
Arthur
Only one state of a bool to be shown in AES/Events section
- arthur
Re: Only one state of a bool to be shown in AES/Events section
If the TRUE state raises the CAME alert you can filter in the AEScreen only for the CAME alerts.
Then only the CAME alerts will be shown for any alarm.
- arthur
Thank you for your reply, but I was referring to the 'Events' (Bottom) section of the AES, where and I need to show:
- type 1 alerts: both 'CAME' and 'WENT' states are displayed
- type 2 alerts (which I cannot configure as 'impulse'): 'CAME' only state to be displayed.
Is there any standard method to do that?
Kind regards,
Arthur
Kind regards,
Arthur
No. in the Event Screen the value changes are displayed and there is no possibility to filter for specific value changes.
- AMRPatricio
Hi Leopold,leoknipp wrote: ↑ Thu Mar 18, 2021 11:43 am If the TRUE state raises the CAME alert you can filter in the AEScreen only for the CAME alerts.
I am currently facing similar issue. Regarding the functionality to display only CAME event alerts within the alarm list. Such functionality/filter seems to be available only while in Open or Close Mode. In Current mode such option seems not to be available. Is this correct?
Thank you in advance.
Antonio Patricio
Yes, it is correct that filtering for the alert direction is only possible in Open or Closed mode.
