[Bug?] [3.17] Very Strange Behavior with Overriding Protected Callbacks in derived Classes
moto3101
Post by moto3101 »
Hello together,
I recently came across a very weird behavior when trying to override callbacks in derived classes in CTRL++.
please consider the following simple example
(for reasons of space I put everything together)
Dpl for Import
# ascii dump of database
# DpType
TypeName
TestPump.TestPump	1#1
	State	25#2
	Value	21#3
# Datapoint/DpId
DpName	TypeName	ID
Pump1	TestPump	18246
Code Example for CTRL manager
class BaseLogic
  public BaseLogic()
    //default constructor
  public void init()
    setupConnect();
  protected void setupConnect()
    dpConnect(this, this.cbOnPumpStateChanged, true, "Pump1.State");
    dpConnect(this, this.cbOnPumpValueChanged, true, "Pump1.Value");
  // can be overridden
  protected void cbOnPumpStateChanged(string sDpPumpState, string sState)
    DebugTN(__FUNCTION__,sDpPumpState,sState);
  //must not be overriden
  private void cbOnPumpValueChanged(string sDpPumpValue, int iValue)
    DebugTN("Private Callback");
    DebugTN(__FUNCTION__,sDpPumpValue,iValue);
class ExtendedLogic : BaseLogic
  public ExtendedLogic()
    //Default constructor
  //@Override:
    DebugTN("Overridden method for callback");
public void main()
  ExtendedLogic logic;
  logic.init();
  dpConnect("cbTest", false, "Pump1.State"); //just to prevent the ctrl manager from exiting
public void cbTest(string dp, string state)
When trying to run this, you will get a very weird exception:
SEVERE,     73, Variable not defined, Line: 14, this.cbOnPumpStateChanged
However, when you change the visibility of the overriding method in ExtendedLogic to public (public void cbOnPumpStateChanged), it works.
Expected behavior:
It should be possible to use a protected method in a derived class for overriding a callback from a super class
I would consider this as a bug, please let me know if you agree or if the behavior is intended.
Thanks!
moto3101
Re: [Bug?] [3.17] Very Strange Behavior with Overriding Callbacks in derived Classes
Post by moto3101 »
There also seems to be a problem with the "this" operator for protected methods:
Executing this
class BaseLogic
  public BaseLogic()
  public void init()
    this.setupConnect();
    DebugTN("baseClass SetupConnect!");
    DebugTN("derived class SetupConnect!");
public void main()
  logic.init();
Results in an error:
SEVERE,     73, Variable not defined,    Line: 10, this.setupConnect()
When just calling setupConnect(); (and deleting the "this.") it works
moto3101
Re: [Bug?] [3.17] Very Strange Behavior with Overriding Protected Callbacks in derived Classes
Post by moto3101 »
Should I additionally report this as a bug?
