I have read the Knowledge Base article on this topic and tried to follow the instructions but I am having a real problem to get this solution:
A dpDisconnect() can only be made in the same script like the dpConnect()!
I have tried to put the dpConnect/dpDisconnect work function the same event, but it does not seem to work on 3.15 P033.
WCCOAui (1), 2021.03.08 21:25:10.629, CTRL, WARNING, 72, Function not defined,
But, the connect worked the previous event from the same code. The dpConnect and dpDisconnect are in the same event. The work function is in the same object code (not on ScopeLib). I've tried to put it all in ScopeLib too, it does not seem to matter.
Can anyone tell me the criteria for "same script"?
Todd Malone
dpDisconnect
Re: dpDisconnect
Can you please copy the complete code where we can see the dpConnect/dpDisconnect to the thread.
Also please give the information in which script in the UI you have defined the code.
