Use duplicated objects on SIMPLE SYMBOL
pablo.chamorro
Post by pablo.chamorro »
We start using the 'Simple Symbol' functionality and we are exploring it's limits. It works fine if we create a simple symbol like a pump but, if we create a complex symbol that contains multiples pumps (new panel where we drag and draw multiples pump objects), in the assign symbol to DPTs the $_parameters only appears once because they share the same $_Parameters. There is a way to make it works or we have to create each pump in the new panel and change the $_Parameters for each one?
We use V3.17 P007
Thanks.
gschijndel
Re: Use duplicated objects on SIMPLE SYMBOL
Post by gschijndel »
In the property editor and/or reference panel you could set a new dollar parameter as dollar value (like $pump1 or $station + ".pump1").
