PowerConfig conflict at rename a DPE
pablo.chamorro
Post by pablo.chamorro »
After create my Master DPT and add all needed PowerConfigs on it and created the DPs, I saw I need to rename a DPE.
After rename the DPE, the DPEs configs on the DPs becomes a normal config, like the DPE never had PowerConfigs but, if I try to insert the powerConfigs again I can't because it's checked like it exists yet.
How is it posible? It's no able to edit a DPT after create a Master DPT?
Re: PowerConfig conflict at rename a DPE
For master datapoints the information at which elements power configs are added is written to the original values of the datapoint _dt_<type name> (DP type _DynamicDatapoints).
If an element is renamed possibly the information at the original values is not updated and therefore the power configs do not work properly afterwards.
