how unload pdf files?
feixiang
Post by feixiang »
Dear specialist,
Does anybody known how unload pdf files while use PDF Viewer EWO?
I load a pdf file like that Pdf_ewo1.load("D:/Pdfs/abc.pdf"); It's work properly.
after switch to another pdf (eg,def.pdf)file, I try to delete this pdf(abc.pdf) but failed.
the error message is :
the action can't be completed because the file is open in ui Executable.
anybody known how solved it?
feixiang
Re: how unload pdf files?
This problem is already fixed in 3.16 and 3.17.
If you install the newest patches for these version the "old" file is unloaded if a new file is loaded.
feixiang
Post by feixiang »
Thank you very much!
I now use 3.16 p015,
I'll try use the latest patch later.
