UI and config.webclient
9 posts • Page 1 of 1
ask
Post by ask »
In my installation I use 2 types of hosts runnig UI Linux and Windows.
This hosts are connecting via Apache and mxProxy.
In Linux, certificates are stored in files.
In Windowsm is possible to store certificates in Windows Certificate Store.
This requires special entries in config files.
eq. mxProxy="server proxy_server:port cert"
But it works for filebased certificates. For Windows Certificate Store I need to use config "WinCert"
How can I create different configs to distinguish Linux and Windows Clients?
Re: UI and config.webclient
Unfortunately you can not create a common config that distinguishes between Linux or Windows.
gschijndel
Post by gschijndel »
You could try to add the entries for windows in 'config.nt' and for Linux in 'config.linux'.
gschijndel wrote: ↑ Tue Feb 02, 2021 1:08 pm You could try to add the entries for windows in 'config.nt' and for Linux in 'config.linux'.
Nice that works automatically?
mkerk
Post by mkerk »
yes. works automatically.
config files are read in the following order:
Project config file,
config.level file
"config.<os>" (config.nt or config.linux)
config.redu file (in case of a redundant project)
If you activate -dbg 2 on startup of the UI, then you will see which config-files are loaded in which order.
ask
Post by ask »
Thanks!
But I have another questions:
1. Are this files (config.nt, config.linux) automatically loaded via http server or I have distrtibute it manually? If both exists (.nt and .linux) are both loaded or only this one which matches operating system on client?
2. If I have entry in "common" config and the same entry in e.q. config.nt which one is used?
3. Can I use different entries for "securityMode" depending on certain ui manager number?
If you want to use specific settings for a manager with a given number you can use the following syntax for the definition of sections in the config file:
[<manager type>_<num>]
E.g. [ui_10]
This only works if the manager is then started explicitely with this number using the "-num" startup parameter.
First of all the "config" file is loaded. If there are other files existing they are loaded afterwards. An entry in "config.nt" will overwrite the same entry defined in "config".
There is no need to disribute the config files manually to the client. During startup in the HTTP-server the files are loaded and merged to one config file which is then copied to the client.
ask
Post by ask »
Thank You!
But what about config.webclient file? Is this file used by UI manager (WCCOAui) instead of config file?
Or content of config.webclient file replaces relevant entires in config file?
And is it done before or after config.<os> is read?
As far as I know the loading order is config --> config.webclient --> config.nt.
A config.nt (OS related config file) is only needed if you use different operating systems in one WinCC OA project, e.g. a UI started on Windows and one UI started at Linux.
