I need explanation about mxProxy and Apache:
Client connects to http proxy via Apache.
Connections between Client and Apache and between Apache and mxProxy are secured.
Can I use different certificates for connection Client-Apache and Apache-mxProxy and how to configure it?
Or certificates must be the same?
Using Certificates
- gschijndel
Re: Using Certificates
You can use different certificate for the connection browser (ULC UX client) - Apache webserver as Apache webserver - WinCC OA webserver (ULC UX server).
It is not possible to make a connection between the Apache webserver and the mxProxy.
- ask
Thanks!
If I want to pass all traffic via machine in DMZ (and avoid direct connectivity to WinCC OA server machine) I must run Apache and proxy on machine in DMZ?
What if another proxy manager is already runnig on WinCC OA server machine? Should I turn off this proxy?
Best Reagrds
Best Reagrds
