Duplicate a large number of DPE
11 posts • Page 1 of 2
andrea.bertorelli
Post by andrea.bertorelli »
i am trying to replicate my DP structures (now created for plc1 only) for more plc. I exported the configuration of all DPEs starting with "plc1*" from ASCII and replaced it with "plc2". Imported the variables log show me a lot of errors that repeats itself indefinitely for almost all the DPEs.
I use the 3.17 patch 05, the DPEs I export are about 32.000 of which about 1000 are connected with s7plus, the others are "internal". Almost all of them have the _general property active which I use to store descriptions in the dyn_langString.
Also I noticed that in PROJ_PATH/db/ winccoa/ Ive very big databases, could it be a storage limit of these databases?
"textvar.db" 699.052KB
"dynvar.db" 299.595KB
"objNameTxt.db" 147.839KB
WCCILdata    (0), 2021.01.23 12:24:41.933, SYS,  SEVERE,     69, Database error, PersGeneralConfig, storeConfig ,Speicherfehler Config
WCCILdata    (0), 2021.01.23 12:24:41.933, PARAM,WARNING,    22, Internal consistency check for config failed, DataManager, handleValueChangeMsg, Config was not stored correctly (code 4):
System1:plc2_IST_MULTIMETRO.DATI.Tensione_L2L3:_general.._type (Type: 311 Sys: 1 Dp: 20847 El: 14 : _general.._type)
WCCILdata    (0), 2021.01.23 12:24:41.933, SYS,  SEVERE,     69, Database error, DataManTask, dbError, RAIMA Database Error *** Code:-901 (INTERNAL error: -901
bad dchain
C errno = 0: No error
FILE: ..\..\..\ExternLibs\rdm45\runtime\Dio.c(2270))
WCCILdata    (0), 2021.01.23 12:24:41.934, PARAM,WARNING,    22, Internal consistency check for config failed, DataManager, handleValueChangeMsg, Config was not stored correctly (code 4):
System1:plc2_IST_MULTIMETRO.DATI.Tensione_L3L1:_general.._type (Type: 311 Sys: 1 Dp: 20847 El: 15 : _general.._type)
WCCILdata    (0), 2021.01.23 12:24:41.934, SYS,  SEVERE,     69, Database error, DataManTask, dbError, RAIMA Database Error *** Code:-901 (INTERNAL error: -901
bad dchain
WCCILdata    (0), 2021.01.23 12:24:41.934, SYS,  SEVERE,     69, Database error, PersGeneralConfig, storeConfig ,Speicherfehler Config
System1:plc2_IST_MULTIMETRO.DATI.Corrente_N:_general.._type (Type: 311 Sys: 1 Dp: 20847 El: 12 : _general.._type)
bad dchain
CCILdata    (0), 2021.01.23 12:24:41.935, SYS,  SEVERE,     69, Database error, PersGeneralConfig, storeConfig ,Speicherfehler Config
WCCILdata    (0), 2021.01.23 12:24:41.935, PARAM,WARNING,    22, Internal consistency check for config failed, DataManager, handleValueChangeMsg, Config was not stored correctly (code 4):
System1:plc2_IST_MULTIMETRO.DATI.Tensione_L3N:_general.._type (Type: 311 Sys: 1 Dp: 20847 El: 18 : _general.._type)
WCCILdata    (0), 2021.01.23 12:24:42.194, IMPL, SEVERE,     54, Unexpected state, PersDpConfig, setAttribute, TYPE_ATTR erwartet:
System1:plc2_IST_MULTIMETRO.DATI.PotenzaReattiva:_general.._bool_01 (Type: 311 Sys: 1 Dp: 20847 El: 21 : _general.._bool_01)
BIT_VAR 262144 0
WCCILdata    (0), 2021.01.23 12:24:42.194, PARAM,WARNING,    22, Internal consistency check for config failed, DataManager, handleValueChangeMsg, Config was not stored correctly (code 4):
WCCILdata    (0), 2021.01.23 12:24:42.195, IMPL, SEVERE,     54, Unexpected state, PersDpConfig, setAttribute, TYPE_ATTR erwartet:
System1:plc2_IST_MULTIMETRO.DATI.PotenzaApparente:_general.._bool_01 (Type: 311 Sys: 1 Dp: 20847 El: 22 : _general.._bool_01)
BIT_VAR 262144 0
WCCILdata    (0), 2021.01.23 12:24:42.195, PARAM,WARNING,    22, Internal consistency check for config failed, DataManager, handleValueChangeMsg, Config was not stored correctly (code 4):
System1:plc2_IST_MULTIMETRO.DATI.EnergiaAttiva_M:_general.._bool_01 (Type: 311 Sys: 1 Dp: 20847 El: 25 : _general.._bool_01)
BIT_VAR 262144 0
andrea.bertorelli
Re: Duplicate a large number of DPE
EDIT:
I noticed that going to modify the _general of the old DPEs, Ive errors that make me think that there is some corrupted database, below the log trying to modify the _general of a DPE from PARA.
WCCILevent   (0), 2021.01.24 12:08:10.929, SYS,  WARNING,    65, Wrong destination address, (SYS: 1 Driver -num 1 CONN: 1), DP_MSG_SIMPLE_REQUEST
WCCOAui      (2), 2021.01.24 12:08:10.930, SYS,  SEVERE,     38, Message could not be sent, DP: System1:plc1_IST_DATI_JES.DATI.GenVolt_L3_N:_address.._type, MAN: (SYS: 1 Driver -num 1 CONN: 1), Could not send message DP_MSG_SIMPLE_REQUEST #58923
WCCOAui      (2), 2021.01.24 12:08:10.930, SYS,  SEVERE,     38, Message could not be sent, DP: System1:plc1_IST_DATI_JES.DATI.GenVolt_L3_N:_cmd_conv.._type, MAN: (SYS: 1 Driver -num 1 CONN: 1), Could not send message DP_MSG_SIMPLE_REQUEST #58923
WCCOAui      (2), 2021.01.24 12:08:10.930, SYS,  SEVERE,     38, Message could not be sent, DP: System1:plc1_IST_DATI_JES.DATI.GenVolt_L3_N:_msg_conv.._type, MAN: (SYS: 1 Driver -num 1 CONN: 1), Could not send message DP_MSG_SIMPLE_REQUEST #58923
WCCOAui      (2), 2021.01.24 12:08:10.930, SYS,  SEVERE,     38, Message could not be sent, DP: System1:plc1_IST_DATI_JES.DATI.GenVolt_L3_N:_smooth.._type, MAN: (SYS: 1 Driver -num 1 CONN: 1), Could not send message DP_MSG_SIMPLE_REQUEST #58923
WCCILdata    (0), 2021.01.24 12:08:15.572, SYS,  SEVERE,     69, Database error, DataManTask, dbError, RAIMA Database Error *** Code:-901 (INTERNAL error: -901
bad dchain
WCCILdata    (0), 2021.01.24 12:08:15.573, SYS,  SEVERE,     69, Database error, PersGeneralConfig, storeConfig, Speicherfehler Variable
WCCILdata    (0), 2021.01.24 12:08:15.573, PARAM,WARNING,    22, Internal consistency check for config failed, DataManager, handleValueChangeMsg, Config was not stored correctly (code 4):
System1:plc1_IST_DATI_JES.DATI.GenVolt_L3_N:_general.._langString_03 (Type: 428 Sys: 1 Dp: 15467 El: 2453 : _general.._langString_03)
WCCILdata    (0), 2021.01.24 12:08:15.573, IMPL, SEVERE,     54, Unexpected state, PersDpConfig, setAttribute, TYPE_ATTR erwartet:
System1:plc1_IST_DATI_JES.DATI.GenVolt_L3_N:_general.._langString_04 (Type: 428 Sys: 1 Dp: 15467 El: 2453 : _general.._langString_04)
LANGTEXT_VAR 2621440 42
LANG:10029 ""
LANG:10028 ""
LANG:10021 ""
LANG:10015 ""
LANG:10000 ""
WCCILdata    (0), 2021.01.24 12:08:15.574, IMPL, SEVERE,     54, Unexpected state, PersDpConfig, setAttribute, TYPE_ATTR erwartet:
System1:plc1_IST_DATI_JES.DATI.GenVolt_L3_N:_general.._langString_05 (Type: 428 Sys: 1 Dp: 15467 El: 2453 : _general.._langString_05)
WCCILdata    (0), 2021.01.24 12:08:15.574, PARAM,WARNING,    22, Internal consistency check for config failed, DataManager, handleValueChangeMsg, Config was not stored correctly (code 4):
System1:plc1_IST_DATI_JES.DATI.GenVolt_L3_N:_general.._blob_01 (Type: 428 Sys: 1 Dp: 15467 El: 2453 : _general.._blob_01)
BLOB_VAR 3014656 Blob encountered with 0 items, dump follows
System1:plc1_IST_DATI_JES.DATI.GenVolt_L3_N:_general.._blob_02 (Type: 428 Sys: 1 Dp: 15467 El: 2453 : _general.._blob_02)
WCCILdata    (0), 2021.01.24 12:08:15.575, IMPL, SEVERE,     54, Unexpected state, PersDpConfig, setAttribute, TYPE_ATTR erwartet:
System1:plc1_IST_DATI_JES.DATI.GenVolt_L3_N:_general.._blob_03 (Type: 428 Sys: 1 Dp: 15467 El: 2453 : _general.._blob_03)
WCCILdata    (0), 2021.01.24 12:08:15.575, PARAM,WARNING,    22, Internal consistency check for config failed, DataManager, handleValueChangeMsg, Config was not stored correctly (code 4):
System1:plc1_IST_DATI_JES.DATI.GenVolt_L3_N:_general.._blob_04 (Type: 428 Sys: 1 Dp: 15467 El: 2453 : _general.._blob_04)
System1:plc1_IST_DATI_JES.DATI.GenVolt_L3_N:_general.._blob_05 (Type: 428 Sys: 1 Dp: 15467 El: 2453 : _general.._blob_05)
WCCILdata    (0), 2021.01.24 12:08:15.576, PARAM,WARNING,    22, Internal consistency check for config failed, DataManager, handleValueChangeMsg, Config was not stored correctly (code 4):
WCCILdata    (0), 2021.01.24 12:08:15.576, IMPL, SEVERE,     54, Unexpected state, PersDpConfig, setAttribute, TYPE_ATTR erwartet:
System1:plc1_IST_DATI_JES.DATI.GenVolt_L3_N:_general.._long_01 (Type: 428 Sys: 1 Dp: 15467 El: 2453 : _general.._long_01)
LONG_VAR 4587520 0
System1:plc1_IST_DATI_JES.DATI.GenVolt_L3_N:_general.._long_02 (Type: 428 Sys: 1 Dp: 15467 El: 2453 : _general.._long_02)
LONG_VAR 4587520 0
System1:plc1_IST_DATI_JES.DATI.GenVolt_L3_N:_general.._long_03 (Type: 428 Sys: 1 Dp: 15467 El: 2453 : _general.._long_03)
LONG_VAR 4587520 0
WCCILdata    (0), 2021.01.24 12:08:15.577, PARAM,WARNING,    22, Internal consistency check for config failed, DataManager, handleValueChangeMsg, Config was not stored correctly (code 4):
WCCILdata    (0), 2021.01.24 12:08:15.577, IMPL, SEVERE,     54, Unexpected state, PersDpConfig, setAttribute, TYPE_ATTR erwartet:
System1:plc1_IST_DATI_JES.DATI.GenVolt_L3_N:_general.._long_04 (Type: 428 Sys: 1 Dp: 15467 El: 2453 : _general.._long_04)
LONG_VAR 4587520 0
System1:plc1_IST_DATI_JES.DATI.GenVolt_L3_N:_general.._long_05 (Type: 428 Sys: 1 Dp: 15467 El: 2453 : _general.._long_05)
LONG_VAR 4587520 0
WCCILdata    (0), 2021.01.24 12:08:15.578, IMPL, SEVERE,     54, Unexpected state, PersDpConfig, setAttribute, TYPE_ATTR erwartet:
System1:plc1_IST_DATI_JES.DATI.GenVolt_L3_N:_general.._ulong_01 (Type: 428 Sys: 1 Dp: 15467 El: 2453 : _general.._ulong_01)
ULONG_VAR 4784128 0
WCCILdata    (0), 2021.01.24 12:08:15.578, PARAM,WARNING,    22, Internal consistency check for config failed, DataManager, handleValueChangeMsg, Config was not stored correctly (code 4):
System1:plc1_IST_DATI_JES.DATI.GenVolt_L3_N:_general.._ulong_02 (Type: 428 Sys: 1 Dp: 15467 El: 2453 : _general.._ulong_02)
ULONG_VAR 4784128 0
System1:plc1_IST_DATI_JES.DATI.GenVolt_L3_N:_general.._ulong_03 (Type: 428 Sys: 1 Dp: 15467 El: 2453 : _general.._ulong_03)
ULONG_VAR 4784128 0
WCCILdata    (0), 2021.01.24 12:08:15.579, IMPL, SEVERE,     54, Unexpected state, PersDpConfig, setAttribute, TYPE_ATTR erwartet:
System1:plc1_IST_DATI_JES.DATI.GenVolt_L3_N:_general.._ulong_04 (Type: 428 Sys: 1 Dp: 15467 El: 2453 : _general.._ulong_04)
ULONG_VAR 4784128 0
WCCILdata    (0), 2021.01.24 12:08:15.579, PARAM,WARNING,    22, Internal consistency check for config failed, DataManager, handleValueChangeMsg, Config was not stored correctly (code 4):
System1:plc1_IST_DATI_JES.DATI.GenVolt_L3_N:_general.._ulong_05 (Type: 428 Sys: 1 Dp: 15467 El: 2453 : _general.._ulong_05)
ULONG_VAR 4784128 0
System1:plc1_IST_DATI_JES.DATI.GenVolt_L3_N:_general.._bit64_01 (Type: 428 Sys: 1 Dp: 15467 El: 2453 : _general.._bit64_01)
ULONG_VAR 4784128 0
WCCILdata    (0), 2021.01.24 12:08:15.580, IMPL, SEVERE,     54, Unexpected state, PersDpConfig, setAttribute, TYPE_ATTR erwartet:
System1:plc1_IST_DATI_JES.DATI.GenVolt_L3_N:_general.._bit64_02 (Type: 428 Sys: 1 Dp: 15467 El: 2453 : _general.._bit64_02)
ULONG_VAR 4784128 0
WCCILdata    (0), 2021.01.24 12:08:15.580, PARAM,WARNING,    22, Internal consistency check for config failed, DataManager, handleValueChangeMsg, Config was not stored correctly (code 4):
System1:plc1_IST_DATI_JES.DATI.GenVolt_L3_N:_general.._bit64_03 (Type: 428 Sys: 1 Dp: 15467 El: 2453 : _general.._bit64_03)
ULONG_VAR 4784128 0
System1:plc1_IST_DATI_JES.DATI.GenVolt_L3_N:_general.._bit64_04 (Type: 428 Sys: 1 Dp: 15467 El: 2453 : _general.._bit64_04)
ULONG_VAR 4784128 0
WCCILdata    (0), 2021.01.24 12:08:15.581, PARAM,WARNING,    22, Internal consistency check for config failed, DataManager, handleValueChangeMsg, Config was not stored correctly (code 4):
WCCILdata    (0), 2021.01.24 12:08:15.581, IMPL, SEVERE,     54, Unexpected state, PersDpConfig, setAttribute, TYPE_ATTR erwartet:
System1:plc1_IST_DATI_JES.DATI.GenVolt_L3_N:_general.._bit64_05 (Type: 428 Sys: 1 Dp: 15467 El: 2453 : _general.._bit64_05)
ULONG_VAR 4784128 0
andrea.bertorelli
EDIT 2:
I tried using the guide "How to initialize the configuration history?" , which seems to "shift" the problem, if before the errors came out in the middle of duplication now they come out towards the end of the duplication.
It seems strange to me that I exceeded 16,000,000 ID, during import (-in export_configs.asc -inactivateAlert) in the logviewer the list of variables had reached an ID of 309,000, far from the maximum limit
After RAIMA initialization, and the duplication attempt, the largest database file is objNameTxt.db with 147.839KB, and the others are 20mb or less
The log message
bad dchain
refers to some problem in the database.
Some information in the database is corrupted and therefore you get this error.
If you want to get detailed information please get in contact with your common WinCC OA support as there need be done detailed analysis to get information for the cause of the problem.
The log messages
describe that information cannot be read because there is no driver with number 1 running in your system.
If you start the required the drivers in your project these log message will not occur anymore.
andrea.bertorelli
Thanks for the reply!
I was able to solve most of the errors by reloading a very old backup, but I still have problems that Im convinced are related to the general dyn_langString.
Starting from a working project, after initializing the database with the guide, Ive create a simple code that instantiates a list of about 10-15 elements in Italian lang in about 20-25.000 dpes.
And at the end of this process all these errors pop up.
The alarms described below are also "alarm" type, but I assure you that the problem arises only when I do the dpSet of the:
DPE +":_ general.._ dyn_langString"
WCCILdata    (0), 2021.01.26 10:38:33.659, PARAM,WARNING,    22, Internal consistency check for config failed, DataManager, handleValueChangeMsg, Config was not stored correctly (code 4):
System1:plc1_VALVE_TCVx56_Vapore.SGN.ALL_ZT:_general.._langString_04 (Type: 292 Sys: 1 Dp: 21303 El: 50 : _general.._langString_04)
WCCILdata    (0), 2021.01.26 10:38:33.659, IMPL, SEVERE,     54, Unexpected state, PersDpConfig, setAttribute, TYPE_ATTR erwartet:
System1:plc1_VALVE_TCVx56_Vapore.SGN.ALL_ZT:_general.._langString_05 (Type: 292 Sys: 1 Dp: 21303 El: 50 : _general.._langString_05)
System1:plc1_ALL_CONTATORI.WRN_FTx78:_alert_hdl.._active (Type: 429 Sys: 1 Dp: 19856 El: 16 : _alert_hdl.._active)
WCCILdata    (0), 2021.01.26 10:25:15.238, SYS,  SEVERE,     69, Database error, DataManTask, dbError, RAIMA Database Error *** Code:-909 (SYSTEM/OS error: -909
file record limit exceeded
FILE: ..\..\..\ExternLibs\rdm45\runtime\Dio.c(2096))
WCCILdata    (0), 2021.01.26 10:25:15.239, SYS,  SEVERE,     69, Database error, DataManTask, dbError, RAIMA Database Error *** Code:-909 (SYSTEM/OS error: -909
WCCILdata    (0), 2021.01.26 10:25:15.239, IMPL, SEVERE,     54, Unexpected state, PersAlertValue, storeBinaryConfig, getTextAttribut oder storeTextAttribut failed
plc1_MERKER.WRN_LSHx61:_alert_hdl (Type: 0 Sys: 0 Dp: 1062 El: 32 : _alert_hdl..0)
WCCILdata    (0), 2021.01.26 10:23:07.350, IMPL, WARNING,   187, DP: plc1_MERKER.WRN_LSHx61:_alert_hdl: No gone alert between two came ones at 2020.12.30 11:49:20.165 and 2021.01.26 09:33:02.427, AlertAdministration, insertAlert
WCCILdata    (0), 2021.01.26 10:23:07.354, PARAM,WARNING,    46, Attribute was not archived, ManagerInitialiserfillAckAH, Notification class not found - Standard class is being used
plc1_MERKER.ALL_DispG:_alert_hdl (Type: 0 Sys: 0 Dp: 1062 El: 38 : _alert_hdl..0)
WCCILdata    (0), 2021.01.26 10:23:07.354, IMPL, WARNING,   187, DP: plc1_MERKER.ALL_DispG:_alert_hdl: No gone alert between two came ones at 2021.01.11 12:22:32.638 and 2021.01.26 09:33:02.443, AlertAdministration, insertAlert
WCCILdata    (0), 2021.01.26 10:23:07.355, PARAM,WARNING,    46, Attribute was not archived, ManagerInitialiserfillAckAH, Notification class not found - Standard class is being used
It looks like you have that Problem:
https://www.winccoa.com/knowledge-base/ ... e-909.html
As soon as you have more than 16777216 entries, this error message appears.
andrea.bertorelli
Hi!
Thanks for the reply, I had found this thread too, but it didn't provide any tips on how to fix the problem. I was hoping to find some more help here on the forum.
I'll try to contact support!
The log messages you have posted refer to different problems, therefore you will need several solutions to fix all the problems which appeared.
The cause for one problem (file record limit exceeded) is described in the Knowledge Base article. As it can have different reasons (different database parts can be affected) for the log message there is no solution provided in the Knowledge Base article.
andrea.bertorelli
I will shortly send a small report of our problem to the support.
I just wanted to clarify that in reality the problems described above only appear when (in order) we reach the limit of the file. As if properties such as address, alert, pv_range etc ... are also corrupted.
In fact, for these tests we used a program that has been installed for several months and works correctly in all its functions, but if we simply go to massively duplicate the DPEs, properties that previously worked correctly are corrupted. (look for address and alert errors).
It will be interesting to understand what happens!!
Thank you all :geek:
adaneau
Post by adaneau »
This sounds a lot like you are filling up the configuration history there.
Did you try to import your tags with -noAlertConfigHist ?
