dpConnect use
MassEffect
dpConnect use
Post by MassEffect »
Hello!
As far as I know the function dpConnect(callback, DP.property) uses callback function to bind any changes DP.property. Does it exist any function that unbind my DP.property or it will be automatically? That is if I don't need listen to DP.property at the moment than I unsubscribe for event and subscribe if I need it.
adaneau
Re: dpConnect use
Post by adaneau »
Depends where your dpConnect is called:
- in a panel: it will be disconnected when this panel is closed (if panel ref, when ref is removed).
- in a script: it will be disconnected when script is stopped. Be aware that dpconnect is preventing a script to terminate.
If you want fine control, you can always use dpdisconnect.
Best regards
Alexandre
Re: dpConnect use
Just an additional information: The function dpDisconnect() must be called in the same script which has called dpConnect(). Otherwise the dpDisconnect() does not work.
MassEffect
Re: dpConnect use
That is all scripts that bind to panel or grafic elements, buttons in panel etc. (on events like - initialize, click, focus and so on) unbind than I close appropriate panel?
That about scripts that running with control manager?
adaneau
Re: dpConnect use
Post by adaneau »
Yes that's correct. Sorry I wasnt really clear by using the word "script", I meant running inside ctrl manager.
Best regards
Alexandre
MassEffect
Re: dpConnect use
Thank you very much!
