Install only OPC DA Server
maherhodali
Post by maherhodali »
In our server we have installed WinCC OA V16, this server is on production now. OPC DA Server seems is damaged. Is there procedure to uninstall only OPC DA Server and reinstall OPC DA Server only without affecting the full installation?
Re: Install only OPC DA Server
It is not possible to deinstall/install only a single WinCC OA process.
You have to install the complete WinCC OA version.
Maybe the problem can be solved without doing an installation.
If you need further assistance please get in contact with your common WinCC OA support.
