unfortunately I am not able to connect a OPC UA Server. (none-none - but with user/password authentification)
In the log there is some entry that says "StatusCode: BadSecurityModeInsufficient".
Has anyone faced the same problem?
Thank you very much in advance.
Mathias
OPC UA Client - BadSecurityModeInsufficient
- adaneau
Re: OPC UA Client - BadSecurityModeInsufficient
The message is relatively clear, it seems that the server you are trying to connect requires you higher security, eventually sign or sign&encrypt. Check in your server if you can change this and it should work.
Best
Alexandre
Best
Alexandre
