Translate several DPEs of type dyn_langString
andrea.bertorelli
Post by andrea.bertorelli »
Using the Translator tool, I cannot export the contents of dyn_langString DPEs. Is there a way to translate them easily or I have to manually translate every single DPEs in all languages?
Thanks!
Andrea
Re: Translate several DPEs of type dyn_langString
the Translator tool is only for panels and message catalogs
adaneau
Post by adaneau »
If they are DPE, you can always use ASCII export to work on a csv file instead of para.
Alexandre
With the "Translator" tool you can also translate information saved in the database.
According to the WinCC OA Documentation the "DP description" and "alert textes" can be exported and translated.
It looks like original values cannot be translated using the "Translator".
