Error _NGA_G_EVENT
funkey
Error _NGA_G_EVENT
Post by funkey »
I started a new project and was using NGA.
Now I decided not to use the NGA and changed config entry 'useNGA' to 0.
I got a few error logs with datapoints where I had to change the archives, this was no problem.
But I get this errors without datapoint names in log.
WCCILdata    (0), 2020.12.17 10:24:17.541, PARAM,WARNING,    54, Unexpected state, HistOrgMain, no internal archive dp specified in archive class of: -, parametrized dp in archive class is System1:_NGA_G_EVENT
WCCILdata    (0), 2020.12.17 10:24:17.542, SYS,  SEVERE,     54, Unexpected state, HistOrgMain, no valid archive number
WCCILdata    (0), 2020.12.17 10:24:17.542, PARAM,WARNING,    54, Unexpected state, HistOrgMain, no internal archive dp specified in archive class of: -, parametrized dp in archive class is System1:_NGA_G_EVENT
WCCILdata    (0), 2020.12.17 10:24:17.543, PARAM,WARNING,    54, Unexpected state, HistOrgMain, no internal archive dp specified in archive class of: -, parametrized dp in archive class is System1:_NGA_G_EVENT
WCCILdata    (0), 2020.12.17 10:24:17.543, SYS,  SEVERE,     54, Unexpected state, HistOrgMain, no valid archive number
WCCILdata    (0), 2020.12.17 10:24:17.544, PARAM,WARNING,    54, Unexpected state, HistOrgMain, no internal archive dp specified in archive class of: -, parametrized dp in archive class is System1:_NGA_G_EVENT
WCCILdata    (0), 2020.12.17 10:24:17.544, SYS,  SEVERE,     54, Unexpected state, HistOrgMain, no valid archive number
So how can I find out where I have to make the changes.
Or is there generally a problem when changing a project from NGA to RAIMA?
Thanks for answers?
Re: Error _NGA_G_EVENT
If you have a project which shall be converted from NGA to RAIMA/HDB you will have to change a lot of settings:
-- config file
-- progs file
-- internal datapoint settings
-- _archive config settings
Why aren't you creating a new project using standard archiving (RAIMA/HDB)?
