dpDelete with DpId
EricSchrön
dpDelete with DpId
Post by EricSchrön »
Hallo everyone,
is it possible to delete a datapoint with the dpid? Similar to the function dpDelete("dpname") I'm looking for dpDelete("dpid"). Is there a solution or a workaround for this?
Thanks for answer!
Eric
Re: dpDelete with DpId
you can get the name by using dpGetName() and use the result for dpDelete()
EricSchrön
thanks. I was suprised that this worked, because I had a problem in dp-name which was formerly iso-language an was written with an "Ü". And this one I could not delete in the para but with this way it worked.
