c.fraenzer
Posts: 8 Joined: Wed Jun 12, 2019 4:19 pm
NGA Influx Mass para Bug
Post
by c.fraenzer » Fri Nov 27, 2020 3:51 pm
Hi guys,
following Problem came up and i could reproduce it under Windows 10 and Different Linux Systems
Using the Master Datapoint i changed the Archive Config of 196 Datapoints. When doing so i ran in to the following fault
WCCILpmon (1), 2020.11.27 15:00:55.933, SYS, WARNING, 36/pmon, Blockierenden Manager WCCOAnextgenarch(1) gefunden. Kein Lebenszeichen seit 30 Sekunden.
this happend whenever i tried to change Archive Config to fixed and then set the config parameters to "only log on changed value".
When checking the influx it seems to me that there where to many Querys at once.
I could reproduce this down to 125 Datapoints in one change. All Above put out this fault.
I am running the current patch.
Has anyone run into a similar problem?
Posts: 2928 Joined: Tue Aug 24, 2010 7:28 pm
Re: NGA Influx Mass para Bug
Post
by leoknipp » Mon Nov 30, 2020 9:35 am
I have tested it in a project where I have created 200 datapoints for the datapoint ANALOG1.
When changing the configuiration of the _archive config no problems occur.
Which patch are you using in detail?
