RAIMA Database Error *** Code:-6
Flick
Post by Flick »
WCCILdata - SYS/SEVERE Database error, DataManTask, dbError, RAIMA Database Error *** Code:-6 (PROGRAMMER/USER error: -6
My colleague had an app crash and has not been able to recover the project since. The Gedi will run but the SysMgm drop down menu is empty, opening SysMgm from the tool bar returns a panel with you have no permission to display this panel message.
We have a backup of the project so it's not an issue, but I'm trying to figure out how the database has gotten so broken. I think with have lost all our users including root....
So I'm wondering what RAIMA Database Error *** Code:-6 means for a start.
I'm on v3.16 P016
Re: RAIMA Database Error *** Code:-6
Only with this part of the log messages we cannot see possible causes for the problem. Probably there are more log message written which refer to the problem in the database.
If you need more information please get in contact with your common WinCC OA support.
Please be aware that you have to stop all WinCC OA processes properly before shutting down the computer.
A loss of power while the WinCC OA project is running can cause a damaged WinCC OA database. Therefore, in a plant system it is recommended to use a UPS.
