I have a slider component on panel and want to change datapoint element connections based on slider value.
This is working OK but because dpConnect and dpDisconnect functions must be called from the same script, how could I initialize connections when panel is opened ? Slider change event updates connections but how to trigger that event manually with default value ?
Regards, Teemu
How to trigger shape event
- teemu_ylonen
Re: How to trigger shape event
No can do thing ? It is also useful information
- adaneau
You could use a function from scope lib inside your event instead of direct coding. Then call this function in init. Be careful however as your disconnect will not work at init as nothing will be connected.
Alex
Alex
- teemu_ylonen
Hi Alex and thank you for your reply.
If you call dpConnect in panel init, then you will get warnings when doing dpDisconnect on slider event. After trying several things, my solution was to do both dpConnect and dpDisconnect on slider event. Then in panel initialization trigger manually slider event by setting slider value something else than zero. This will generate slider event and panel can be initialized. Not the most elegant way but it seems to be working.
Regards, Teemu
Regards, Teemu
