Select ALL historical query fails via GUI
kyle.stotz.ext@siemens.com
Post by kyle.stotz.ext@siemens.com »
I am having trouble using the system management SQL-Query tool to query for historical information.
I find the following in my logfile. How do I find and install the specified missing shared object (using WinCC OA 3.15 running on RedHat)?
WCCOAui (1), 2020.10.29 12:07:31.711, CTRL, INFO, 0, , Couldn't connect to data base xyz, libclntsh.so.12.1: cannot open shared object file: No such file or directory
DBMS API Library 'libclntsh.so.12.1' loading fails
This library is a part of DBMS client installation, not SQLAPI++
Make sure DBMS client is installed and
this required library is available for dynamic loading
Linux/Unix:
1) The directories in the user's LD_LIBRARY_PATH environment variable
2) The list of libraries cached in /etc/ld.so.cache
3) /usr/lib, followed by /lib
Re: Select ALL historical query fails via GUI
Which type of database are you using to store historical data (RAIMA/HDB or RDB)?
The option "SELECT ALL" must not be used. If you want to historical events you have to use "SELECT" and for alerts "SELECT ALERT".
