The project is running in WinCC OA 3.14 P014, Windows server 2012 Standard R2.
When I write multiple data fast from UI. The DB manager will became purple, then restart unexpected in 10 second.
I have added -dbg all in DB manager, but I can not find anything unnormal related with this situation.
I wonder if there any way to locate the problem.
Project restart unexpected when I write multiple datapoint fast from UI
- BenjaminSeeker
Re: Project restart unexpected when I write multiple datapoint fast from UI
What does "write multiple data fast from UI" mean in detail?
How many values are changed in which time interval?
Which function is used to set the values?
Is the UI only changing original values or also other configs?
What is the use case of writing so much data in a short interval?
