correct data point's value using Control's script
MassEffect
Post by MassEffect »
I have a data point's archive, how can I correct my data point's value at a certain point of time using Control's script?
For example,
at first I use dpQuery() function for getting next archive's values:
MyDataPoint.myElement:_online..value = 150
MyDataPoint.myElement:_online..stime = 2020.09.04 12:15:00.350
then if I want to corect them I have to use correct values like these
MyDataPoint.myElement:_corr..value = 190
MyDataPoint.myElement:_corr..stime = 2020.09.04 12:15:00.350
but what functions or steps do I have to use for setting these correct values?
As far as I know then I could use dpQuery() fucntion with _offline's config element of MyDataPoint to see a result:
MyDataPoint.myElement:_offline..value = 190
MyDataPoint.myElement:_offline..stime = 2020.09.04 12:15:00.350
Re: correct data point's value using Control's script
Assuming the variable Ttime has the value of MyDataPoint.myElement:_online..stime
dpSetTimed(Ttime,"MyDataPoint.myElement:_corr..value",190);
MassEffect
Thank you so much!
MassEffect
Another small question)
How can I remove any changes that was added using the function dpSetTimed(Ttime,"MyDataPoint.myElement:_corr..value",190)?
There is no possibility to delete values which are already saved in the WinCC OA archives.
You can only modify an existing value by writing a correction value for the same time again.
MassEffect
Thank you!
